Direct Connect hublist support board. http://dchublist.org
ADCS TLS CERTIFICATE INFO.
News, versions and bug fixes info here.
4 posts • Page 1 of 1
by Admin » Fri Mar 08, 2019 8:17 pm
1.Why would You need to download hub's certificate?
Although ADCS hubs are encripted, there is a small risk of getting "cheated" by so called Man in the middle attack. https://en.wikipedia.org/wiki/Man-in-the-middle_attack.
Therefore downloading hub's TLS certificate and placing it in your clients "Certificates" directory will eliminate this kind of issues.
2.What do i do with it?
Well, after downloading it, place it in folder Certificates in DC++ or any other DC client that you might be using atm. Usually for users using Windows OS this will be in users -> Username -> AppData -> Roaming -> DC++ -> Certificates or:
Code: Select all
%USERPROFILE%\AppData\Roaming\client_name\Certificates
Just drop the cert there, restart the client and reconnect to hub.
Now hub has T or S status for trusted or secured. There is no need of renaming it - hublist generates unique id for each cert file provided.
3.How do i upload certificate file as a hub owner?
Step 1. Make sure your hub software supports ADC protocol.
In older NeoModus protocol only verlihub (latest versions) has a way to do encryption.
So if you using Ptokax, YnHub forget about certs! Just stay the way u are.
For adc hubs that are able to serve via ssl or tls (adcs://) and latest verlihubs proceed to step 2.
Step 2: Make sure to setup adcs:// connections or on verlihub nmdcs:// so your hub address indicates encryption. If it is all setup properly - you can upload your hub's certificate (must be in .crt format) via hubs edit page. Upload option is in your menu under edit hub. Login to https://dchublist.org to get access to it.
Good luck and happy and safe sharing.
/Edit 5.1.2020 - removed .zip requirement./ Hades.
Re: ADCS TLS CERTIFICATE INFO.
by Esential » Fri Mar 08, 2019 10:17 pm
I think above needs to be edited a little bit.
:mrgreen:
Esential
by Admin » Sat Mar 09, 2019 10:43 pm
Feel free to do so.
:mrgreen:
by Delion » Sat Mar 16, 2019 2:51 pm
Under normal for users using Winows OS this will be usually in users -> Username -> AppData -> Roaming -> DC++ -> Certificates.
Better use
Code: Select all
and then \client_name; it is an universal way.
Still wanna have crt-checked hubs to be marked somehow inside the common list of hubs. https://www.iconfinder.com/icons/111039/key_icon or https://www.iconfinder.com/search/?q=checkbox or something like. Or maybe even with another background color?
P.S. Tried to put utf-8 'lock' smile char like Husaria using, but forum SQL base said NO WAY.
Return to HUBLIST NEWS, RELEASES & UPDATES.
cron
  • Re: Crutial - secret. 2021 by Admin
  • Patriot - free speech network android app. by Admin
  • Re: What is the best stylus pen for a windows 10 2 in 1 lapt by juliadavid
  • Re: Some backups by Delion
  • Re: How to compile ADCH++ 64 bit in Ubuntu Linux 20.04.1 by Delion
  • Happy New Year! by Admin
  • Re: Some 'DC over TLS' explanations by Delion
