Hublist hub page [ FIXED ]
6 posts • Page 1 of 1
by Delion » Sat Jan 12, 2019 5:44 am
1) No direct clickable link to join hub(?!).
2) When editing - Protocol always turns to NMDC.
3) Can't add https link (it turns into non-working) to this forum, just http.
4) Hub owner can't delete unwanted comments.
5) No Report button both for hub and comments.
Re: Hublist hub page
by Admin » Sat Jan 12, 2019 10:02 am
1. Hubs name in clickable - takes directly to hub if dc client is installed correctly.
2.This is only when hubsoft used is FlexHub - bug reported on flex dev page.
3. Link please - i can't reproduce this issue.
4. will look into it.
5.Hubs comment report should be posted as feature reqiest seperately.
There is hub report currently via contact at hublist page menu:
https://dchublist.org/contact where we can choose problematic hubs addres and state the problem. Can be used to communicate problems as well as report.
by Delion » Sat Jan 12, 2019 1:00 pm
Hubs name is clickable
Wow. Seems to be sooner an easter egg, then feature, don't you think? Hublist page SHOULD contain a clearly visible direct link IMO.
No, this bug appears every time I do changes on Babylon page.
Link please - I can't reproduce this issue
Try click forum link on Babylon page now.
Soooo many clicks(
And what if user wants to report NOT his own hub?
by Admin » Sat Jan 12, 2019 9:40 pm
Delion wrote:Hublist page SHOULD contain a clearly visible direct link IMO.
It is a direct link - first link on the hub's page - whoever wants to join just clicks the hub name to enter. It works and ppl are using it acording to apache logs often every day.
Oh yes - you are right. It's in hubs edit page not hub page. That's why i didn't see it. But i got it now and yes, it does happen. Will have to have a closer look. This section was done by me - prototype, just few months ago. I didn't put too much thought into it apparently. Gonna make it a bug report Thanx.
Yup. This is clearly a bug .For now just enter web addresses without http:// or https:// it ads it automatically.
Soooo many clicks(
For now scrolling down to find the hub is the only option there.
It is inconvenient i agree but this is original from hubtracker - i didn't mess with that part so far.
There is big blue contact us botton thou. Easy to use and its freeform. U type whatever it is. It can be used to live chat when im available too.
by Delion » Sun Jan 13, 2019 11:14 am
I'd never guess if you didn't tell me...
Well, make it underlined at least. Please?
by Admin » Sun Jan 13, 2019 2:00 pm
I have created a list to work on - this and many more issues will be corrected within next version. Please be patient as some of this will require some time and testing also.
https://forum.dchublist.org/viewtopic.php?f=2&t=202
Users browsing this forum: No registered users and 2 guests
  • Slight server issues with unstable provider. by Admin
