Cannot be pinged while minslots 5 set [ SOLVED ]
10 posts • Page 1 of 1
by Delion » Sat Aug 29, 2020 6:32 pm
https://dchublist.org/685-babylon.html
Tried to change pinger INF, but no luck.
Re: Cannot be pinged while minslots 5 set
by Admin » Sat Aug 29, 2020 11:13 pm
By default pinger declares 3 open slots.
Changed to 7 ATM next ping should do fine. Lets see.
Doesnt ping. Can we get a log somewhere?
Changed slots to 7 then 10 it errors out with:
Error: expected disconnect, received: &adc.InfoPacket{Msg:(*adc.RawMessage)(0xc000091820)}
Whats the min share and other requirements? Can you try changing slots to 3 and see if this is really the issue?
Re: Cannot be pinged while minslots 5 set [ PROBLEM ]
by Delion » Sun Aug 30, 2020 10:58 am
Hm. AFAIK uHub reports its minshare and minslots actually...
Anyway: minshare: 1GiB, minslots: 5, min 'user' hubs: 2
The last option was added just recently and minslots caused problems before (I did that test already by reverting restriction to 1 open slot).
Done.
by Admin » Sun Aug 30, 2020 12:37 pm
OK. Let me see now. I think it will work now.
by Delion » Sun Aug 30, 2020 2:09 pm
Minslots 3 did it.
However what if I raise minslots to 15?..
by Admin » Sun Aug 30, 2020 6:51 pm
I think up to 9 slots will be fine now.
by Delion » Mon Aug 31, 2020 10:49 am
Hmmm.
Are custom pinger options functional? Seems to be not.
https://prnt.sc/u92eoj
by Admin » Mon Aug 31, 2020 12:52 pm
Only on legacy, old pinger. New one runs preset. I did set slots to 20 seems like no hubs are set to limit number of open upload slots for now,
so it's ok. Since you running uhub in strict tls 1.3 don't use legacy ping it won't ping.
by Delion » Mon Aug 31, 2020 4:16 pm
Aha, I see now.
Thanks for help!
Re: Cannot be pinged while minslots 5 set [ SOLVED ]
by Admin » Tue Sep 01, 2020 8:03 pm
No problem.
Thanx for reporting. This could lead to potential issues in the future.
[pkpjok
Users browsing this forum: No registered users and 33 guests
