YnHub - NMDC - Windows strict -[ OUTDATED ].
DC hub software that is supported.
2 posts • Page 1 of 1
by Admin » Mon May 25, 2015 1:20 pm
Fully supported soft unfortulately not currently developed.
Check post below!
You must enable this option in security menu: Check sender ip on ConnectToMe and Search -to be listed here.
YnHub_1.0.364.126.zip
(1.56 MiB) Downloaded 2856 times
YnHub_1.0.363.723.zip
(1.42 MiB) Downloaded 2776 times
YnHub_1.0.362.898.zip
(1.98 MiB) Downloaded 2780 times
Re: YnHub - NMDC - Windows strict.
by Admin » Wed Sep 23, 2015 6:59 pm
A "bug" was reported. Aparently our Pinger sends a key that is invalid to YnHub. For now please uncheck check for invalid key box in YnHub setting so our pinger can get all needed stats - otherwise it will show no info and error - unable to get infos.
I will work on a fix soon but for now time is money.
Check the image to see what to uncheck.
Return to SUPPORTED SOFTWARE
Users browsing this forum: No registered users and 112 guests
