RUSHUB - NMDC & ADC [ ABADONED ].
DC hub software that is supported.
1 post • Page 1 of 1
by Admin » Mon May 25, 2015 1:23 pm
Fully supported - nothing to worry about.
Looks abadoned though. Sadly.
http://mydc.ru/rushub/
Log of changes in RusHub versions:
Code: Select all
07/10/2012 rushub v 2.3.10 , lua plugin v 2.9
Fixed: Updated Zlib 1.2.7.
Fixed: Updated Lua 5.1.5.
Fixed: Fixed some minor bugs, leaks, glitches.
Fixed: Code refactoring and partial support for the ISO C++ standard.
 03.03.2012 rushub v 2.3.9 , lua plugin v 2.8
Added: Added a message to show on first disconnect after frequent reconnects.
Added: The English.xml.example language file has been added.
Added: Added a single timer for login duration: iTimeoutLogon.
Fixed: Modified time format in logs.
Fixed: Fixed a bug that occurred during ipv6 connection.
Fixed: Fixed a bug in anti-flood shutdowns (inconsistency with settings).
Fixed: Updated tinyxml to version 2.6.2.
Fixed: Removed timers and their corresponding settings:
 iTimeoutKey, iTimeoutNick, iTimeoutLogin, iTimeoutMyinfo. iTimeoutGetpass.
Fixed: Fixed bug in nickname check.
Now, if a user with a profile of -1 enters, and there is already a user with the same nickname on the hub, then the incoming one is disabled. If a user enters with a profile not equal to -1, then the one who is on the hub with his nickname is disconnected (protection for registered connections from broken connections).
rushub_2.3.10_win64.rar
(242.78 KiB) Downloaded 882 times
lua_plugin_2.9_win32.rar
(213.29 KiB) Downloaded 900 times
lua_plugin_2.9_win64.rar
(239.24 KiB) Downloaded 906 times
rushub_2.3.10_win32.rar
(212.99 KiB) Downloaded 1910 times
Return to SUPPORTED SOFTWARE
Users browsing this forum: No registered users and 6 guests
