Open DC HUB [ OUTDATED ].
DC hub software that will not work properly.
3 posts • Page 1 of 1
by Admin » Sat Jul 28, 2018 6:44 pm
Unsupported as is on devel website.
Gives possible fake soft due to weird $Lock it sends.
Download our fix below.
Entire fixed source.
Just unzip then configure - make and make install just like any sourcecode.
Please note this fix only addresses hub soft and version detection issue.
You will get a working soft that shows in hublist with user stats but there is
Unable to get infos (unknown error) - will look into this when i find some time to kill.
All other bugs and code issues remain for developers' fix.
opendchub-0.8.3.zip
(210.16 KiB) Downloaded 1029 times
Re: Open DC HUB
by Demona » Tue Jul 31, 2018 11:14 am
Fix indeed only solves issue with hubsoft name and version detection.
Infos in ODCH are still sent in a weird way.
The outcome?
Well hub shows correct number of connected users in real time - stats are medded up.
- how?
For example if ODCH has 100 connected users now, pinger will show it has 100 users but will put incorrect stats - meaning in user number history via graphs it will be completely false.For example one or two...
This needs work.
Demona
Re: Open DC HUB
by Admin » Sun Sep 09, 2018 10:25 pm
This is software issue.
So im unable to fix it.
Return to UNSUPPORTED SOFTWARE
Users browsing this forum: No registered users and 5 guests
