Direct Connect hublist support board. http://dchublist.org
nmdc:// [ REJECTED ].
Moderators: The Crow, Derek
14 posts • Page 1 of 2 • 1, 2
by Delion » Sat Nov 24, 2018 12:19 pm
Now hublist uses NMDC hub addresses like dchub://blahblah:411
No need for default 411 port to be stated btw.
Maybe use nmdc://blahblah.nop:411 ? It is modern and supported by all clients these days.
Seems just cool)
Re: nmdc://
by Admin » Sat Nov 24, 2018 1:43 pm
I'm nor sure if i understand this correctly.
NMDC by defaults assumes hub uses port 411 - if not specified otherwise.
This hublist doesnt assume any postr - port specification is required during registration and wont be accepted without one.
Re: nmdc:// [ UNDECIDED ] .
by Delion » Sat Nov 24, 2018 4:38 pm
My initial idea was turn dchub// links into nmdc:// links to be more modern since adc:// is here for ten(!) years.
Maybe I should note also, that for nmdc:// links port is not optional, even default.
Second though of mine is that if dchub:// links are already used, they could easy be cutted to be more readable.
Look at the options: Image
by Admin » Sat Nov 24, 2018 6:26 pm
is nmdc:// supported by strong dc? linuxdc++, dcgui ?
Re: nmdc:// [ FEATURE REQUEST ].
by Delion » Sat Nov 24, 2018 6:41 pm
Hell yes! It's ancient.
by Derek » Sat Nov 24, 2018 6:58 pm
I will look into that.
Replacing dchub:// with nmdc:// is a trivial fix.
Problem might be with what clients support that - i will have to make sure this won't cause a drama before we move on.
by Admin » Sat Nov 24, 2018 6:59 pm
Trivial fix?
Yeah about 120 lines of code to edit in probably at least 20 files.
:roll:
by Delion » Sat Nov 24, 2018 7:26 pm
Not sure if you can find clients NOT support that...
Re: nmdc:// [ TO DO ].
by Admin » Sat Nov 24, 2018 7:43 pm
Once verified with client support this will be implemented with next major script upgrade.
Prob in 2019.
by Derek » Sun Nov 25, 2018 9:13 pm
Client support might be ok.
Problem is here:
When nmdc:// link is generated via PHP on some page browsers like chrome or firefox don't link it to dc client. They do that fine in case of dchub://
So for now dchub:// is more reliable - i suggest to hold on with that for now.
Next
Return to REJECTED FEATURES
cron
Users browsing this forum: No registered users and 0 guests
  • Re: What is the best stylus pen for a windows 10 2 in 1 lapt by juliadavid
  • Re: Some backups by Delion
  • Re: How to compile ADCH++ 64 bit in Ubuntu Linux 20.04.1 by Delion
  • Happy New Year! by Admin
  • Re: Some 'DC over TLS' explanations by Delion
  • Re: ChitChat - before we do "stuff", let's talk about it her by Delion
