Missing hubs
Other discussions that do not fit in any other category.
Moderators: Derek, The Crow, akruk
6 posts • Page 1 of 1
Missing hubs
by PreferedCustomer » Tue Apr 16, 2019 12:43 am
So a week ado my computer went down and i had to install DC++ on another computer. the current ver 0.868 does not have all the comic hubs i was using is there any to get them back? I think 2 of them were purgatory & perfection.
PreferedCustomer
Re: Missing hubs
by Admin » Tue Apr 16, 2019 11:04 am
Canadian comics hubs are private and do not allow pinger checking.
They are all included in our hublist but show offline for that specific reason.
For example:
https://dchublist.org/hub-188.html
https://dchublist.org/9108-babo.html
What you can do is use search to look for any hubs in our database using a keyword comics for example. Some will show offline or unable to get info - thats ok because u can still connect to them by clickng on hub's name.
Hope this helps.
Re: Missing hubs
by PreferedCustomer » Tue Apr 16, 2019 6:39 pm
When I add those url's it says downloaded hubs are corrupted or unsupported.
PreferedCustomer
Re: Missing hubs
by PreferedCustomer » Tue Apr 16, 2019 7:58 pm
So no Canadian hubs appear in the search list.
PreferedCustomer
Re: Missing hubs
by Admin » Wed Apr 17, 2019 9:16 pm
Do not add urls they won't work, add acctual addresses with port. For example dchub://example.com:port
Add this to your favs in D.C. client.
Re: Missing hubs
by PreferedCustomer » Thu Apr 18, 2019 11:15 am
Thank you, that worked.
PreferedCustomer
Return to HYDE PARK.
Users browsing this forum: No registered users and 19 guests
