VERLUHUB - LINUX STRICT - NMDC. [ ACTIVE ].
DC hub software that is supported.
5 posts • Page 1 of 1
by Admin » Mon May 25, 2015 1:02 pm
Low ram usage and low on CPU.
Fully supported - any version will do just fine.
Get the latest version here:
https://github.com/verlihub
else to avoid exploits:
Verlihub 0.9.8C and older
To determine the hub to ignore wrong CTM's: !set check_ctm 1
To determine the hub to check CTM's and kick the user: !set check_ctm 3
To determine the hub to check active searches: !set check_asearch 1
To determine if the hub is set up correctly: !getconfig
Verlihub 0.9.8D and newer
To determine the hub to check CTM's and kick the user: !set check_ctm 1
To determine if the hub is set up correctly !getconfig
We will remove all hubs running verlihub versions lower than 0.9.8e-rc2 soon.
So please update!
verlihub-master.zip
Verlihub 1.3.0.x Source.
(975.67 KiB) Downloaded 1195 times
verlihub-0.9.8e-r2.zip
(878.11 KiB) Downloaded 2273 times
verlihub-0.9.8e-r2.tar.bz2
(479.37 KiB) Downloaded 2305 times
Re: VERLUHUB - LINUX STRICT
by Admin » Wed Feb 24, 2016 1:10 pm
Looks like Verlihub Version: 2.0.0-RC1 and 2.0.0.0 is somewhere outhere.
Not publically released yet.
Shows up in our stats :)
Re: VERLUHUB - LINUX STRICT - NMDC. [ ACTIVE ].
by CyberGhost404 » Sun Jan 20, 2019 4:58 am
Hi, this software use Verlihub 1.1.0.41 version =)
[*] dchub://dc.elitedc.ru:411 - Direct Connect HUB
[*] http://hub.elitedc.ru - #EliteDC.ru StatDC
CyberGhost404
by Admin » Thu Feb 21, 2019 5:23 pm
Hublist support
There are some variables of the hub configuration that are sent to hublist pinger when it enters in the hub. These are:
hub_name: the name of the hub
hub_desc: the description of the hub
hub_category: the category of the hub (this is only used by dchublist pinger)
hub_host: the address and port of the hub (you can omit 411 default port if you want)
min_share: minimum value of share that user must have to join
min_slot: minimum value of slot that user must have to join
max_hubs: maximum number of allowed hubs
hub_owner: the owner if the hub
VerliHub has also a very simple hublist registering support for those hublists that have a registration server. Use the following variables to setup hublist registration:
hublist_host: a list of hublist registering host separated by space (reg.dchublist.org + whatever else you want).
hublist_port: the port of the registration server (port 2501 is the default one)
You can manually register the hub by using the following command:
!hublist
VerliHub is also capable of automatically register the hub every each interval of time. The variable timer_hublist_period specify the time in seconds that VerliHub should wait to between two hublists registrations. For example if you want to register your hub every 10 minutes use:
!set timer_hublist_period 600
Automatic registration is disabled by default. If you would like to disable it again use the value 0.
We have 2 versions of hublist servers here - currently in use ver 1. won't take any verlihubs regs if option hublist_send_minshare =1 . Please set it to 0.
2nd server is in production - it will take verlihub's regs no matter what settings are. Just need to enter dchublist.org:2501 as hublist regserver address and use command !hublist to reg manually (once) or set it to auto !set timer_hublist_period 600
Re: VERLUHUB - How to setup TLS?
by Admin » Wed Aug 07, 2019 10:49 pm
Verlihub 1.2.0.5 and later TLS 1.3 now possible via go-lang programming.
https://github.com/Verlihub/tls-proxy
Expect double of connections while running this stuff.
Return to SUPPORTED SOFTWARE
Users browsing this forum: No registered users and 2 guests
