PTOKAX - NMDC - linux, windows and ARM.
DC hub software that is supported.
13 posts • Page 1 of 2 • 1, 2
by Admin » Mon May 25, 2015 1:18 pm
Fantastic soft!
20 years anniversary in 2022!!!
New release with bugfixes and new LUA version below!
All versions will work just fine.
Please DO NOT USE any versions older than 0.3.5.2 (became a hacktool).
PtokaX 0.4.x.x
go to Settings, Advanced, Advanced security and be sure that the option to Check if user send correct ip in protocol command (DDoS protection) is enabled.
PtokaX 0.3.5.2 or 3.6.0.0
go to Settings,then Options tab and make sure that the option to 'Check user IP in commands' is enabled.
PS:
When messing around with language files please leave phrase "This hub is running" alone - dont translate it or soft verssion wont be detected in some cases - especially when cyrilic / russian is used.
0.5.3.0-54-64.zip
Windows x64 LUA 5.4.4
(21.82 MiB) Downloaded 1153 times
0.5.3.0-51-64.zip
Windows x64 LUA 5.1
(21.68 MiB) Downloaded 1159 times
0.5.2.2-53-64.zip
(17.34 MiB) Downloaded 1475 times
0.5.2.2-53.zip
(17.01 MiB) Downloaded 1446 times
0.5.2.2-nix-src.zip
(10.48 MiB) Downloaded 1387 times
Re: PTOKAX - NMDC - linux and windows.
by The-Master » Tue Feb 16, 2016 12:20 pm
Small bug discovered, when trying to ban multiple IP's, hubsoft crashes, reported to PPK ;)
The-Master
by Admin » Tue Feb 16, 2016 1:34 pm
On what PtokaX version was that bug?
by The-Master » Tue Feb 16, 2016 2:58 pm
Latest release, 0.5.2.1 Linux and windows versions, software runs oke, just don't try the bug, it's tested and confirmed. will be fixed by PPK asap ;)
The-Master
by Demona » Tue Feb 16, 2016 3:04 pm
Thanx for that info.
- avoid that release then ppl.
I think best PX is 0.4.1.2 - solid!!
Demona
by The-Master » Wed Feb 17, 2016 6:50 am
Why? because of 1 small bug? Its the best hubware there is.
Read the Changelog and you'll find lots of other bugs already found and fixed. ;)
The-Master
by The Crow » Wed Feb 17, 2016 11:10 am
I think she meant to avoid that particular release until it is fixed.
There is many versions of PX to pick from as she stated 0.4.1.2 is one of the most stable ones - i think so tooooo.
Most of big hubs use that release for years now.
But i am not a specialist in PX :)
The Cure "Burn".
The Crow
by The-Master » Wed Feb 24, 2016 11:37 am
Well no..
I ment because of a small bug, it's no reason to not use this stable software, just don't cause the hub to chrash by testing the bug..
Another small bug found by me btw..
by selecting script in gui, and moving over disabled scripts, those scripts state the memory use of the moved, running script..
Bug reported to PPK and action will be taken ;)
The-Master
by The-Master » Wed Feb 24, 2016 12:21 pm
In fact.. using 0.4.1.2 is not save.. read this post-->http://dchublist.org/board/viewtopic.php?f=10&t=54#p68
The-Master
by Admin » Wed Feb 24, 2016 12:32 pm
You are right Master.
Exploit has been fixed in PtokaX version 0.5.0.3 as of 2015-02-20 so anything earlier than that is bad.
Next
Return to SUPPORTED SOFTWARE
Users browsing this forum: No registered users and 370 guests
