Direct Connect hublist support board. http://dchublist.org
DC security - keeping DC clean !!
Other discussions that do not fit in any other category.
Moderators: Derek, The Crow, akruk
4 posts • Page 1 of 1
by Admin » Wed Aug 12, 2015 8:53 pm
As some of You already know DC has some serious flaws in coding. What that means is that by running any DC server You might contribute to hacking , DDoS attacks and some nasty exploits that some weird individuals use to kill web servers wordwide.
What can be done to avoid this?
1. Use updated hub server software like latest Ptokax and Verlihub.
Other hub softs we had no chance to test yet....
2. Avoid HexHub - it has a nasty backdoor and no matter what version it is hackers can use it to do nasty things to innocent folks outhere.
3. If you noticed your hub (ip) was used to send ddos attack - please report it here ... Give us your hub soft name and version - thats all we need.
On our side we will make sure that in the future all servers running malicious software will be removed and banned at dchublist.org.
There is absolutely no reason to have entire DC dye because of few individuals who decided to use DC as hacking and attack tool because they have nothing better do do aparently.
God bless!
Re: DC security - keeping DC clean !!
by Pinche » Thu Dec 03, 2015 1:31 pm
Well your hublist has CTM exploit check - thats good news!
Here is Rolex's post (3 years old but still well worth reposting).
Hi all good and bad DC users and developers out there.
I guess it's time to reveal second largest exploit in NMDC history that I found about 9 months ago. Do you remember the good old CTM exploit discovered by Team Elite back in 2006? Well, this one is pretty much alike.
How does it work?
Extremely easy I would say, all you need to do is to send malicious active search request to any vulnerable hub:
How it should be
$Search 2.3.4.5:12345 F?F?0?1?mp3|
How we do it
$Search 1.2.3.4://2.3.4.5:12345 F?F?0?1?mp3|
Where 1.2.3.4 is your own IP address and 2.3.4.5:12345 is the target IP address with port number that we would like to flood using UDP traffic. In most cases your own IP address needs to be real, because the hub might ignore your search request or even kick you due to mismatch between your real IP address and the one stated in the request.
If the hub is not filtering requests with invalid port number, a vulnerable hub, it will broadcast the message to all its users. Each user who shares any MP3 files on the hub will then respond by sending 10 search results using UDP traffic to address 2.3.4.5:12345 mentioned in our example.
That is one malicious request in one hub, now imagine thousands of bots sending these malicious requests non stop to several public hubs with 5000 users on each, you should be able to hear a bomb exploding on target side. I did alot of tests actually, and came up to receiving traffic at speed of 1 Gbit/s, at that point hardware limits were reached. It should be possible to push the record even higher with better hardware.
What is servers mistake?
In above example 1.2.3.4://2.3.4.5:12345 the server takes 1.2.3.4 as the IP address of the request, which is correct, and //2.3.4.5:12345 as the port number of the request. Does the second part look like a port number? Not to me, but to server it does, sadly.
What is clients mistake?
In above example 1.2.3.4://2.3.4.5:12345 the client takes 1.2.3.4:// as invalid protocol of the request, and 2.3.4.5:12345 as the IP address and port number of the request, which are correct. I keep wondering for long time, but can't understand yet why DC++, StrongDC++ and other clients apply function Util::decodeUrl on active search request address. I was on the other hand very glad when I saw that clients didn't apply that function on active CTM request.
Which servers are vulnerable?
The only hub software that initially did check for invalid port in CTM and Search request was FlexHub, any other hub servers were forwarding the requests as is, allowing the exploit. I fixed the exploit in Verlihub 1.0.0 RC2 as of 2014-06-14 and about same time Lord_Zero fixed it in his HeXHub. Today we can see that most largest hubs on DC run PtokaX, which is still vulnerable. It is now known that exploit has been fixed in PtokaX version 0.5.0.3 as of 2015-02-20.
Which clients are vulnerable?
Every single one of them are. I was only looking at DC++, StrongDC++ and few other based on them. The exploit is fixed in AirDC++ version 2.91 and in all FlylinkDC++ versions since 2015-02-21. DC++ fixed the bug since release version 0.851 and ApexDC++ since version 1.6.2 released on 2016-05-28. StrongDC++ and ApexDC++ are is still vulnerable.
What's the most interesting part?
The most interesting part about this exploit is that UDP protocol is portless, meaning that target server will receive all UDP traffic regardless of any open ports or firewalls at server level. By sending as much traffic as target server download speed allows, you will overwhelm the target connection and the server will no longer receive and respond.
What can we do about it?
Fix this, sure, but how? If we look back at CTM exploit, yet today we see hubs that don't check for valid IP address in CTM requests, from that we can learn that there will always be hubs running old vulnerable hub servers even after 10 years. By that I'm trying to say that first of all fix should be implemented in DC clients, to protect its users.
Final words
I'm not sure if this is a mistake initially made by server developers or client developers, probably both are involved equally. No matter the answer, this exploit is the second largest exploit after CTM, and it's standing before you.
I'm really proud to present this exploit for you because DC developers need to learn and to see what they are doing, to stop making such trivial mistakes.
Have fun fixing your servers and clients, and ofcourse get prepared for people flooding each other using this exploit, that's what humanity has always been doing - making war against eachother.
Posted by RoLex on 2015-02-08 12:42 • 9 likes
So yes its important as hub owners to check hub security settings and use lates versions of actively developed softs.
Same with regular folsk - so called users.
Pinche pendejo :mrgreen:
Pinche
by Esential » Sat Apr 16, 2016 9:56 pm
Pinche Pendejo :)
hahahahhahahahahahahhahahahaha
Love your nick.
:lol:
Esential
by Admin » Sat Apr 16, 2016 10:23 pm
Old stuff but still so good.
Return to HYDE PARK.
Users browsing this forum: No registered users and 2 guests
  • Happy New 2026 Year folks! Best wishes. by Admin
  • Re: Removed, banned, locked hubs. by Admin
  • How to Enable Windows Photo Viewer on Windows Server. by Admin
  • PY-DCHUB (OphioDcHub) Os independent python. by Admin
  • JDBHUB by Dark BIOS. Java - os independant [Outdated]. by Admin
  • Re: AirDC++ [ Up to date] by Admin
  • Re: DSHub 0.5.5 (former Death Squad Hub). [ABADONED] by jassyyy
